So a lifter fell during my cam swap and i have loosened the pan i have a flex magnet and i have poked around the engine i cant find the lifter anywhere, some one please give me an idea of where and how to find this thing. thanks for the help.
take the pan all the way off, remove the oil pickup tube, remove the windage tray and fish the lifter out. You need a new oring for the oil pickup tube. Put a small bead of silicone around the pickup tube oring on the side opposite the oil pump when reinstalling it.
how do i get the pan out of the truck, there just isnt enough room ro get the pan out with the oil pickup there.
remove/unbolt the crossmember and it will come right out.
really, it seems to hit the trans housing and i worried about damaging somthing, i did pull the crossmember but i really dont want to break something else, its a 4x4 if that makes a difference. is there a certain way to move the pan so i can get it out.
It should drop straight down. You did remove the two bolts at the bottom of the transmission that holds it to the pan, right?
o yeah i took those two bolts out, i missed them at first but the pan still hits the front drive axel for the 4wd.
Can't you remove/unbolt the front diff?
its not that easy, there are all kinds of wires and bolts holding it on there. i just need to know if i can get the pan over that axel so i can get the pan out.
