Results 1 to 10 of 12
Thread: A few questions
    Jun 2010
    A few questions
    Hi guys im new here and have a few questions. I have a 1993 chevy k1500 that im dieing to do a swap with a 5.3. now i have a 4l60e which has a 12pin connector? correct? can i use a nelson harness to control it with a pcm out of a new vehical with the 5.3 or do i need to use my old computer? also is there headers for the 4wd obs trucks with the swap?
    thank you
    Nov 2009
    Fort Smith, Arkansas
    Im pretty sure you can use your tranny with the new computer but may involve some harness modification.
    And no, there isnt a company that makes conversion headers for the 4wds. Atleast not that I know of. It has been verified that the Schoenfeld conversion headers will not work on a 4wd.
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    Jun 2010
    ok thank you very much. i planned on getting a harness from nelson so he can proabably deal with that. and so the 4wd conversion guys are just using manifolds?
    Nov 2009
    Far as i know. There might be some shorties thatll work?
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    Nelson tuned
    Jun 2010
    ok thank you! ill do a little more snooping around.
    Quote Originally Posted by 93ecss View Post
    The stock manifolds flow pretty decent for a stock motor, they are the same casting up through the 6.2L's that are making 400+ HP. . Why not try to get the motor up and running on them? They fit on my 93, I even had the 2004 y-pipe tucked up in there with a little clearancing on the left pipe to clear the frame. On my latest swap, the engine is sitting about 30mm further back, so making takedowns that clear the frame shouldn't be an issue.
    Mike
    http://kds-performance.com
    Jun 2010
    Quote Originally Posted by beertestr View Post
    alright sweet! do you have a build theard? or any pictures of your swap?
    yup thread is HERE
    Mike
