Results 1 to 7 of 7
Thread: 2 codes
    Oct 2003
    stuttgart,ar
    Where or what is bank 2 senser 1? P0154 & P0155, both are
    at the same place ^. what do those mean?
    2000 SWBRC 5.3,radix,e-fans,no cats,true duels
    2 21/2in delta force race muffs,4.10 with eaton
    e-locker.Descreened MAF & throttlebody bypass.
    FLP level 5 4L65E,PI 3000 stall,Dynatech headers
    Nelson tune
    2005 GMC 2500HD 4door 4x4
    1989 Chevy Suburban 4x4 ( Sir Leaks-a-Lot )
    Jan 2005
    Humble/Houston TX
    bad 02 sensor. im not sure exactly which one but one of the others will chime in.
    old mod list: H/C/I/N/E/G 408
    bank 2 is the passenger side. Sensor 1 is the front one and 2 is behind the cat.
    Follow this link for all the information you never wanted to know about how to determine which bank is 1 or 2 and which sensor is 1 or 2.....
    http://www.asashop.org/autoinc/june2002/techtips.cfm
    Dec 2004
    Benton Arkansas
    bank 1 sensor 2 is the sensor closest to the motor on the passenger side.
    Daily driver: '97 Z-71 reg. cab, electric fans, dual bats, K&N cold air, custom built muffler, and your standard blue light special equip...
    My Baby: '67 GMC swb small back glass. 388ci stroker, old school bowtie heads est. 450hp, scat steele crank, eagle H beam rods, and Keith Black pistons, but only pushing 10:1 compression, fed by an Edelbrock 750 carb. THM350 trans. shiftkit w/manual valve body, 2800 stall going out back to some highway 3.42 gears, tubbed.
    Oct 2003
    stuttgart,ar
    Thanks,how much is one and who makes the
    best?Dont want to change it again a month down the
    road. Would it be best to change both sides
    ahead of the cats?
    Nelson tune
    Dec 2004
    Benton Arkansas
    im not sure how much they are, but i have used bosch and they have worked for me. i can get you a price tonight when i go to work. all we carry is bosch in 02 sensors. bosch plugs suck ass but their 02 sensors are ok.
    Jan 2005
    Humble/Houston TX
    i stuck with the oem when i changed mine out. they werent expensive at all.
