Results 1 to 7 of 7
Thread: engine wont rpm
    Feb 2009
    engine wont rpm
    I finally got my swap completed yesterday. Motor runs great when I keep the rpm around 1000. If I slowly open the slow the throttle it only revs to about 2000. If I mat it it won't do anything. My buddy put his modis on it and checked everything out and everything was reading like it should. Any ideas?
    04 Z06 LS6- 230/232 cam, 4l60 w/ 3600 Yank
    bad or no grounds? did you upgrade your fuel pump? The fuel pressure/volume required for these engines is enormous compared to the older trucks. What fuel pressure regulator are you using?
    Feb 2009
    I used the vette regulated filter with the walbro 255 pump for the g/n. I have about 53 psi of fuel at the rail. Maybe my grounds aren't good enough I just repainted the whole engine bay while it was out. I check those and see if it helps.
    Feb 2009
    Another buddy brought his hp tuner up n found the pcm had a 2000 rev limiter, so he changed that and we are good now.
    Nov 2009
    Fort Smith, Arkansas
    2000rpm rev limiter??!!! HAHAHA!!
    '91 2WD RCSB
    5.3l L59 DBW
    4L80E
    TR220 cam
    RevMax 2800rpm stall converter
    Schoenfeld LT Headers
    Nelson tuned
    My Truck Video - http://www.youtube.com/watch?v=Rw9y1...&feature=email
    hot & windy
    Quote Originally Posted by flattopwill View Post
    x eleventy-billion
    the only time my truck only operates between 1000 & 2000 rpm is after i hit the fuel cutoff
    99 Sierra - 5.3 / 5spd
    Feb 2009
    Yea we were kinda confused. After I get exhaust on it this weekend ill try to get some pics and a vid up.
