Results 1 to 10 of 11
Thread: 4L60E lockup bypass?
    Feb 2009
    Tulsa, OK
    Is there such a thing?
    I saw a bypass kit for a 700r4 and was wondering if there is a way to do it to the 4L60E?
    if you don't want the TCC to lock up you can cut the signal wire from the PCM and extend the wires to a toggle switch on the dash to turn it on or off.
    Feb 2009
    Tulsa, OK
    Would it hurt the transmission to do it?
    MidnightRider Guest
    no it wont hurt it, but why would you want that? you should also be able to bypass it with the tune.
    Broken Bow, OK
    What are benefit are you trying to get out of it not locking up?
    Might throw a code. Would be a neat feature for rolling up hills and not lugging.
    The newer transmissions use a new PWM valve that gives it partial lockup which might complicate things, but you can swap out for the pre-95 valve (so it's either locked or unlocked).
    May also think it's slipping and enter full pressure mode or throw a code.
    Buffalo or Rochester, New York
    Quote Originally Posted by 2500Ak View Post
    I noticed that sometimes I get two levels of lockup, depending on how hard I push the gas going up a hill or under a load. I always wondered how that worked.
    Cowboy, if you drive it with your foot instead of cruise and can push the gas pedal down a little the tranny will usually drop lockup on its own before grabbing third, at least thats how mine works. A bunch of my buddies with diesels have the manual lockup switches and i think it would be neat to have one too. They all have built sled puller transmissions though.
    Kyle - 2004 K1500 Z71 RCSB 5.3
    - Nelson 93 Octane Tune - LPP Long Tubes + Y - Gibson Extreme Duals - Cut Up Stock Air Box - 10.95 @ 67 in the 1/8 -
    - '05 Pickup Front Brakes - '05 Suburban Rear Brakes - Russel Stainless Braided Hoses -
    - DTRL's Turned to Park Lights - 4-HI Mod - '05 SS Seats -
    - I downshift near hybrids so they can hear me hurting the environment. -
    I would think it would make your trans run really hot.
    casey23 Guest
    No reason to disable lock up... unless u want to put 2-3 units in there before you figure out that is a bad idea.... I notice you have a Circle D stall.. You have enough parts its time for a Live tune !
    Feb 2009
    Tulsa, OK
    Well here was my thinking...I thought when the stall was locked up your not really getting much from it as far as your power to tq conversion. Say I want to pass a car and I'm going 50 mph (in lockup). If the TC is locked up I'm not getting as much foward momentum when it down shifts? Right?
    I thought if I could turn it off I would get more out of it and still get mpg's when I want em?
    I'm in the process of installing the tc, shift kit and a 4/6 drop. The tc will be in this weekend.
