Results 1 to 10 of 20
Thread: best way to fit 22s on an 09?
    Feb 2010
    im looking for the best possible way to fit 22 inch rims with 305/45 tires on my 09 silverado. i know about leveling kits and small lifts that rough country makes but i was wondering what eveyone has been doing to clear these huge rims and tires. any input is greatly appreciated.
    Round Rock, TX
    Put them in the bed!!!
    Jan 2010
    Cedar Park
    On the 09's i dont think you would need to do anything for those tires to clear.
    Crossett,Ar
    I was kinda thinking the same as above....
    wichita falls, tx
    On a 09 u could actually drop the rear and level it
    there is tons of room in the wheel wells
    they will fit,my buddy runs 27s on his nnbs stock height.
    Round Rock, Texas
    I thought they stuffed 30'' wheels on a NNBS without much modification.
    Feb 2010
    i should have been more specific i have a 4x4 silverado. i think you guys are running 2wd right? i installed one on the front left and it rubbed like crazy about half way turning to the left on the inner fender and mud flap... ive seen one truck with a 2.5 inch leveling kit and they had to trim some sheet metal from the inner fender because they still rubbed.
    Wichita Falls, TX
    Your offset may be too low. that's only a 32" tire right? I had 325/65/18 on my 00 Z71, a little trimming of the plastic, no lift. The 325/65 is a 34X13" tire. You shouldn't have any problems with that tire unless the wheels only have a +10 or 0 offset.
    wichita falls, tx
    yeah unless you have the wrong offset you shouldnt have any problems at all.
    i have a +35mm offset 22 with a 285/35/22 front and rear with a 6/8 drop and i dont rub at all
