Results 1 to 9 of 9
Thread: What to do, what to do?
    Dec 2009
    Denton, Texas
    Hi all, newbie here. I have a 96 C2500 with the 5.7 L31. It has been very reliable truck from the get go. Recently though it has developed a loud valve train noise when first started for the day. It will stop after about a minute. Lifter bleeding down? Time for rebuild? I am the original owner and have changed oil and filter every 3000 miles. I would like to keep it for a long time so I don't mind putting some money into it. I have never had the motor apart yet. Any suggestions?
    Augusta, Ks
    When in doubt yank it out. jk
    Are you wanting to keep the 5.7 or modernize it with a 5.3 or 6.0?
    2004 Buell XB12s
    verify the oil pressure with a mechanical gauge. If the oil pressure is fine then swap the lifters out, they've been in there a long time.
    Dec 2009
    Denton, Texas
    Thanks for the prompt replies. I was going to keep the 5.7 just because. How much would you think I would gain by going to a 6.0, given a budget of $5000? One thing I don't have to worry about with a 3/4 ton is emissions - I don't even get tested.
    Augusta, Ks
    For $5000 you could have a nice setup.
    6.0 will have alot more power than the tired 350
    $700-$1000 for a 6.0
    $650 for harness from Nelson Performance
    $300 Tune from Np
    $500 for cam, springs, Pushrods
    $5000 will take you a long way.
    2004 Buell XB12s
    Sep 2009
    Charleston, SC
    Quote Originally Posted by 3/4 ton randy View Post
    Is that because of the vehicle weight or does Texas not test emissions? Just curious.
    03 ecsb LS1Cam (4now), Electric Fans, Exhaust, Ported TB, rebulit 4l60 w/shift improvements&stall 130amp Alt,Magnaflow exhaust
    http://www.cardomain.com/ride/3101653
    GM Performance parts also has a nice 383 Vortec for that year model.
    Supposed to be a direct swap, but will need tuning.
    I think it has 400tq as well, that would be a nice upgrade and still under budget.
    Dec 2009
    Denton, Texas
    Texas does have emissions testing for vehicles, so I guess I'm not tested because of the gross vehicle weight. Also, vehicles older than 25? years are exempt.
    Welcome to the site! I would honestly not even waste money on trying to rebuilt or modify that motor. Invest the money into something that will give you a worthwhile result--like a 6.0L.
