Results 1 to 10 of 18
Thread: dual batteries?
    Rhode Island
    dual batteries?
    can you hook up dual bateries in nbs gas truck with the painless wireing dual batteries hook up. or are the other ways?
    06 GMC 2500HD EC/SB 6.6 LBZ allison 6 speed, 4" MPRP turbo back, QS2 on the 70HP tune
    2000 chevy2500 RCLB 6.0
    4L80E,4.10s,aem intake,180 t stat,ported tb,descreened maf, true duals with high flow cats and 40s dumped, lt285/75r16 MTs,an a hypertech programer for now saving for a custom tune now its dead
    15.9 at 88 with mudd tires
    1973 chevy k10
    1989 chevy k1500 stepside
    Wire the batteries in parallel. + to +, - to - to ground.
    Wichita Falls, TX
    That's an easy way, or if you want to keep one isolated as a backup you can wire in an isolator relay. Say you spend a lot of time running your radio and want to be sure you can start your truck afterwards. Wire the relay to be controlled by the main ignition(pink wire, green plug at bcm, stays on during crank). Either way works, just depends on your needs.
    Quote Originally Posted by lo-lyf View Post
    Yep, depends what you need. I was just stating the simplest way, but you know that =)
    Wichita Falls, TX
    Simplest is best sometimes. Parallel is probably what most people need anyway. It's usually lake goers and tailgate partiers that need the isolated battery.
    I ran my yellowtop and Batcap in parallel with a 250amp alternator... no problems, even pushing 3200 watts for two hours.
    Isolated is a different story. I can give you a write up tomorrow if you need it. It's quite simple. I'm just too drunk and tired tonight.
    Rhode Island
    sounds good send it whenever you get a chance
    1973 chevy k10
    Quote Originally Posted by hillbilly6.0 View Post
    Fairly just this right here is exactly what you need to see...
    Battery Isolators
    Rhode Island
    good info thanks
    1973 chevy k10
