Results 1 to 10 of 12
Thread: Wanted Z06 Cam (2002+)
    Nov 2004
    Norman, OK
    I'm looking to purchase a Z06 cam, prefer low miles, must be from a 2002 or newer Z06.
    Thanks,
    (I'd also like the part number if anyone has one)
    Why Don't You Ask Me What It Feels Like To Be A Freak?
    2004 RST
    Apr 2003
    Mansfield, Texas, USA
    FYI... the '01 is a lil better truck cam.
    Tighter LSA, less exhaust duration, std base circle allow 7.4" rods too...
    Jun 2003
    North Central Arkansas, Cave City
    I would agree, I have the 02 cam in my LS1 and it makes good HP but it does it at a high RPM. I used the stock push rods with my 02 cam with no problems.
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Sep 2004
    What are the differences in the cams as far as the usefull rpm range? I had the '02 cam put in my truck a week or so ago and love the power between 2200 and the rev limiter, but if I'm below 2k on the tach I have to kick it down a gear to get it rolling.
    Here's an 02 cam on ebay Ebay Cam
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    Apr 2003
    '01 = 204/211 116LSA
    '02 = 204/218 117.5LSA
    Lift is a tad more on the '02+ but I can't tell you exactly. Also the '02+ has the smaller base circle so it needs the slightly longer rods too.
    EDIT - Fixed incorrect info!
    Sep 2004
    Hmmmm. I have the '02 in my truck with the stock pushrods and all seems to be working well. I hope these don't sound like stupid questions, but I just don't know enough to know.
    What difference would the shorter rods make? Are my valves not closing all they way? My mileage did drop from around 15 to around 12mpg. I've been thinking I need a tune to fix that.
    Ross
    Don't you mean you need longer push rods? Smaller base circle and shorter rods would be a real no-no unless you like the sound of a solid lifter cam.
    Sep 2004
    That makes sense to me?
    Apr 2003
    Yes, you're correct. They need to be ~.050 longer.
    Sep 2004
    Would that be why I get some valve train noise? It only occurs after the engine is really warm. I've been trying to decide if it's valve train or detonation, since it only occurs when the engine is really warm.
    I thought vavle noise would be more prevalent when the engine is cold.
    Ross
