Thread: Muncie/T-10/Saginaw LS Conversion KIT
    Tyler, TX
    I just got Keisler Engineering to compile a quote for anybody who has ever been interested in putting an early model Muncie M22/21, or T-10/SuperT-10 style transmission behind an LS style engine. This is really handy for retrofitting ls engines to 60's gm muscle cars while keeping the same transmission and drivetrain. so here are the specs and descriptions along with prices.
    Keisler Engineering, Inc.
    2250 Stock Creek Blvd
    Rockford, TN 37853
    Due Date Terms
    10/15/2009
    Rep
    865-609-8187 X1 Sales
    865-609-8287 Fax
    email: sales@keislerauto.com web: tremec | 5 speed | 6 speed transmission | Classic car restoration | hydraulic clutch kit | ford transmissions | chevy transmission | dodge transmission
    02 SILVERADO AT
    621 Reproduction GM bellhousing for LS series engines, re-engineered by Keisler with thick wall titanium-aluminum alloy construction and CNC machined
    in-house. 168 tooth flywheel Best 621 reproduction bell on the market- MADE IN USA!
    239.95
    ROLLER PILOT BEARING ASSEMBLY FOR JAGUAR 5.3L, GM LS, AND
    OLDSMOBILE
    49.00
    FWG-460535R, LS FLYWHEEL, LIGHTWEIGHT 17LB FORGED STEEL,
    168TOOTH, FOR STANDARD 11 & 12 INCH CLUTCH, INCLUDES DOWEL
    PIN KIT FOR LS CLUTCH (LIST $499)
    325.00T
    GM LS FLYWHEEL BOLTS, SET OF 6 1 26.95T
    CLG-PK1877-04, 11' 1-1/8 X 26 SPLINE HIGH PERFORMANCE CLUTCH KIT
    FOR GM, 650 FT-LB RATED, INCL: MODERN PEDAL EFFORT NODULAR
    IRON PRESSURE PLATE, HIGH TORQUE CLUTCH DISK WITH REBOUND
    CONTROL, PREMIUM USA SEALED RELEASE BEARING, ALIGNMENT
    TOOL, LUBE PACK
    299.00T
    #910 GM/MOPAR PRESSURE PLATE BOLT, SET OF 6 1 15.95T
    HYDRAULIC CLUTCH ACTUATOR PACKAGE FOR STREET ROD/TRUCK
    WITH GM DRIVETRAIN AND MUNCIE 4-SPEED, INCL: MASTER CYL,
    HYDRAULIC THROW-OUT BEARING, RESERVOIR ASSEMBLY, FLUID
    LINES, FITTING KIT, INSTRUCTIONS
    599.95T
    SHIPPING AND HANDLING 69.00
    Out-of-state sale, exempt from sales tax 0.00
    $1,624.80
    www.tjc.edu
    Tyler, TX
    bumpage
    www.tjc.edu
    nice
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
