Results 1 to 7 of 7
Thread: 15" rims
    Evant,tx
    15" rims
    ok ive got a question i have a 2003 chevy with rear disk brakes will 15" rims clear the disk breaks with the right offset so i can mount slicks on them and also will 15" rims fit on the front or do they make a narow 16" rim and tire for the front all for drag racing skinnys on the front wides on the back
    I would use 16's.
    Jun 2009
    Dublin, Ga.
    15's will fit fine on the front but they will require a lot of grinding to the calipers on the rear. thats what i have on my truck right now, 15" aluminum. the steel wheels require less grinding, but you'll still have to grind some.
    Evant,tx
    ok thanx for the info do they make a skinny 15" rim with 6 lugs i was just thinkin 15" because more choices for drag tires also the skinner the tire on the front less drag
    Jun 2009
    Dublin, Ga.
    Quote Originally Posted by cjcalhoun View Post
    i'm not sure. i have never looked for 6 lug skinnies. prolly have to run a 7 or 8" wide on the front with a 6 lug.
    Evant,tx
    ya i work at a tire/repaire shop i can get 6" wide
    Its all about the inside diameter of the wheels. I had done a set of 16" OBS Escalade wheels on my truck, and they didn't fit... I would measure the CL of the hub to the top of the caliper housing...multiply that X2 and you will get the I.D. of the wheel.
