Thread: 2wd trans - 4wd trans
    Jun 2009
    Harrisburg PA
    the 4l60e in my 2wd went out.
    i found a good deal on a 4l60e out of a 4wd truck.
    is it possible to switch the tail shafts to put the 4wd trans into my 2wd truck?
    Wills77
    06 Silverado 5.3
    20's wrapped in Nitto nt420s, airaid intake, k&n, magnaflow duals, custom grill, 2" drop shackles, cowl hood, vette servos, autotek 2000 watt amp and 2 hifonics brutus 12's....
    05 honda trx450r #77
    Fully built MX quad
    Southern WI
    Going off what I've read before, you need to pull the 4wd trans apart and change some stuff in it to accept the 2wd tail. I guess unless you got a super deal on a lower mile 4wd trans, I'd use the money to just buy an FLT or get your blown one built.
    Mike
    2000 RCSB
    yep, gotta totally disassemble both transmissions to swap the output shafts. Major work.
    Jun 2009
    Harrisburg PA
    alright thanks guys... ill pass on that one....it was out of a wrecked 02 silverado with 70k miles
    Wills77
    06 Silverado 5.3
    Fully built MX quad
