Results 1 to 7 of 7
Thread: 06 silverado 5.3/ 03 gmc savana 6.0
    Jun 2009
    Harrisburg PA
    right now i have a 06 silverado 1500 with a 5.3 and a built 4l60e trans.
    well today the trans went out for the 3rd time.
    i found a 03 gmc savana 3500 van with a 6.0l thats hit lightly in the front but is very cheap.
    does anybody know what trans that van would have in it and what all would be involved in putting the 6.0l and whatever trans it has into my silverado.
    thanks
    Cody Wills
    Wills77
    06 Silverado 5.3
    20's wrapped in Nitto nt420s, airaid intake, k&n, magnaflow duals, custom grill, 2" drop shackles, cowl hood, vette servos, autotek 2000 watt amp and 2 hifonics brutus 12's....
    05 honda trx450r #77
    Fully built MX quad
    That's an LQ4 I bet. Not optimal for NA. The compression is pretty low on them.
    There not so low that there dogs though, there only low in comparison to the LQ9.
    Jun 2009
    Harrisburg PA
    any hp numbers on one with minor mods. exhaust, filter, possibly a nelson tune?
    how would it run compared to my 5.3
    Wills77
    06 Silverado 5.3
    Fully built MX quad
    3500 should have an 80e. It should be just remove and replace one for the other and have the PCM retuned for the swap. You might have to get the driveshafts married to each other to work and the crossmember from the van may not work but its worth trying.
    Tyler, TX
    put a set of 5.3l #706 heads on that lq4, that thing will make plenty of compression, and the dished pistons will give you a smidgen more room for a cam.by the way, 5.3l heads on that engine makes about 11.2:1 compression, thats some horse power making stuff right there
    www.tjc.edu
    True story. Just use the LQ4 shortblock an you'll have an even better runner
