Results 1 to 10 of 17
Thread: Heater Smells?
    Heater Smells?
    When I turned the dial to the hot position on the AC controls I get the sweet smell of coolant. I turn it on and I can still smell it. Any ideas?
    sorry to hear that brother, you need a new heater core.
    Pretty sure that was the case because every now and then I get tiny amounts of coolant on the pass. side floorboard. So can I not use it at all?
    check your coolant level and see if it's gone down
    you can use it at the expense of soaking your carpets with rusty coolant
    Wichita Falls, TX
    That sucks man. I bet its a pita to change just like every other truck.....
    it will make a nasty mess too.
    2003 SIERRA- 5.3 DD
    1985 SWB C10- slow, future plans- shaved, painted, 6.0/4l80e
    Yeah I will take a gander at it sometime tomorrow. Where would it be leaking from if its soaking on the floorboard? I mean I really don't need it, if I just put the control on the hot side itself, it stays warm in there. Plus I have the jeep now.
    What the hell do you even need a heater for?
    just disconnect the hoses at firewall and join them together
    Oh those two. Maybe I will for now so it doesn't leak. I wonder how much is actually stored in the core itself?
