Results 1 to 10 of 15
Thread: vette lt1 purchase ques
    Nov 2004
    hey guys new to the site...been on gmfullsize.com for a while now as Matt over there
    anyways, i plan on buying a vette lt1 in the next year to replace the vortec 4.3 in my 95 half ton sierra. ive done a but load of research into the specifics of the swap and my question is...where would the best place to buy a vette motor. ebay usually has a few, im just tryin to think of different sources to compare prices and whatnot. would a junkyard be an ok place to look for one of these?
    any help is appreciated guys.
    Save your money and go LS1 from a 97+ Vette or 98+ Fbody. You'll save about 75 lbs of dead weight and 400 hp is easily attainable with simple bolt ons, no power adder required. Get it complete with all the accessories. I like the fbody accessories and they are all over the place.
    Apr 2003
    Mansfield, Texas, USA
    'Vette LT1s are aluminum and 4 bolt mains...
    Jun 2003
    North Central Arkansas, Cave City
    They have a cast iron blocks with aluminum heads, the LS1's have aluminum blocks and heads and 6 bolt mains.
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Yep, Vette LT1s only have aluminum heads and intake. I pulled one out of my 92 and replaced it with an LS1 to save the weight plus the LS1 has a hell of a "cool factor".
    Yep, Vette LT1s are the only LT1s with four bolt mains but they only have aluminum heads and intake. I pulled one out of my 92 and replaced it with an LS1 to save the weight plus the LS1 has a hell of a "cool factor".
    Apr 2003
    Ah okay they're 4 bolts but still iron blocks. For some reason I thought they were aluminum also... maybe I'm thinking of the '70 LT1 350?
    Jan 2006
    Las Vegas, Nevada
    <div class='quotetop'>QUOTE(Hit Man X &#064; Nov 10 2004, 11&#58;23 AM) [snapback]20073[/snapback]</div>
    Ah okay they&#39;re 4 bolts but still iron blocks. For some reason I thought they were aluminum also... maybe I&#39;m thinking of the &#39;70 LT1 350?
    Uh, no.... The 70 LT-1 was all iron.... block and heads.....
    1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 3.73 one wheel peel, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics
    1968 Camaro 95LT1/4L60E lots o' mods Web Page
    1961 Corvette project.......... C-4 suspension and brakes, 02 LS1/T-56 awaiting installation Pics
    Nov 2004
    yeah i thought about ls1, but i would prefer the lt1 simply because it will drop right in to my truck and bolt up. i could even use my tranny(which i wont) if i had to.
    but how extensive are the mounting/cutting mods to throw an ls1 in? im going with a corvette motor regardless because of accessory mounting so i dont have to notch my frame.
    i appreciate the replies
    The Corvette LS1 requires frame notching for the a/c unless you mount it high on the passenger side using Street and Performance&#39;s mounts. The Corvette LT1 will require new A/C lines since the compressor is on the driver side and has a bastard fitting for the lines. The LS1 drops right in without any problems, just need motor mount adapters such as the ones they sell at Street and Performance. www.hotrodlane.cc
