Results 1 to 9 of 9
Thread: which a/c relocation bracket?
    Collin County
    Not that this is model specific, buy which a/c relocation bracket has some of you guys used? I am doing a LS motor swap, what are my options? Is there any way that I can use my current compressor or use the LQ4 compressor.
    Thanks. Mr.Ed
    that is a very model specific question. What are you swapping the engine into?
    Apr 2006
    Muldrow, OK
    I used a bracket from Kwik Performance. It bolted up great and looks great. I wasn't able to use the stock compressor though, as it required me to get a Sanden style compressor (SD5, SD7, 508, etc.).
    But its on and works great.
    S&P makes one but it is way more expensive and only comes in chrome...so if you're not all about the bling, it will stand out.
    I'd go with Kwik again if I do another swap. It was easy and pretty cheap.
    Thanks,
    Cody B.
    -Slow Is Not An Option-
    93 Stepside - Forged 347 - LS6 intake - Stage II LS6 Heads - MTI X1 Cam - Vigilante 2800 Stall - HP Tuners - Schoenfeld Headers - 4.11's w/Powertrax - Caltrac's - 430/400
    02 Trans Am - Forged 408 - Single Plane GMPP - 96lb/hr Injectors - HPT 3 Bar - Twin 67mm Turbonetics - Huge FMIC - Moser 9" - 4L80E - Alky Control Meth - Jesel J2K - Eboost2 - waiting dyno
    ff_jeff Guest
    I forgot were I saw one that allows you to keep the stock compressor... I saw it not that long ago. I think I might use it, If I can find it. lol
    Jun 2007
    tulsa, oklahoma
    i used the kwik perf one also, very simple and good people to deal with, bought it from current performance.
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    Monett Mo
    This is one way of using the factory compressor off of a 90s model.
    MalibuRacing.com Message Boards • View topic - A/C Summary
    1992 rcsb k1500 lq4 4l80 swap done.If anyone has questions feel free email as I'm not on here very often. bobby_seitz@yahoo.com
    Collin County
    Quote Originally Posted by 92 6.0 View Post
    sweet thats easy enough. can i also retain the factory compressor off of the 6.0.
    Ed
    STICKY!!!
    Collin County
    Thanks, a lot of good info!
    Gramercy
    josh powers on pt.net has a custom bracket kit that works on our OBS LSx swaps. AC bracket options for LSx swap - PerformanceTrucks.net Forums
    he does great work, i bought his 3/8" adapter plates. very good machine work. good luck oh and you are able to use your stock compressor without having to change lines or anything.
    2008 GMC CCSB 6.2/6L80e swap
