if so what all is needed?
im really thinkin about doing that to my 5.3... if not just gunna go stright to a 6.0
02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
Depends on what you want and what you're building it for...The way I figured it was that I already had the 5.3 and my builder will charge around $200-300 to bore it which was cheaper than buying a 6.0 block and having prep work done on it. Then you just have to buy pistons for the 5.7. You can reuse rods and crank. If you're on a budget, it's not a bad way to go.
You'll need pistons, bearings, rings, heads (compression will be too high with stock truck heads, I went with 317's).
If you are wanting to go forged with a 6.0 or the 5.7, it's the same. What I mean by that is you would have to buy forged parts for both so the cost is pretty much equal. The only difference being if you already have the block or if you have to buy one.
Pistons you can go with Diamond, Wiseco, Probe....
Bearings - Clevite or Federal
Rings - Don't skimp...Total Seal's are good
Heads - 317's will give you lower compression than the LS1's.
What are you building this for? N/A, nitrous or F/I? That makes a big difference as to what parts to put in it.
I have been Planing to do the bore thing w/ my 5.3 and from what i understand running w/ the 5.3 heads would have a compression of around 10.8..
2000 sil.ext. 5.3 / Lingenfelter Ls1 cam / LS1 valves / Ported / Milled / 35lb injectors / 80mm tb / E-fans / cold air intake / Pacesetter Cer LT's w/3"ory/ JET-DST / MSD Twister / Corvette Servo / 3.73's / 125 N2O / no cats / Flowmaster exhaust / level rear drop / Rear sway bar / SS wheels / 285/50R20 Goodyears / 05 Tail lites
1990 454SS-bored .030, small cam, edelbrock intake, Thorley headers, 40 series Flowmaster, MSD ignition, Harland Sharp RRs, e-fans, 160* thermostat, smog delete, 2/4 drop, runs mid-high 13s SOLD
2002 ext. cab silverado-DD
I would think higher than that. With stock 706's and the LS1 I think you will be around 10.8:1. If you mill them I think you'll be over the 11:1 mark. Since the 706's have 61cc, you'll need to get some 243's (64.5cc) or something that has bigger combustion chambers and then get them milled to obtain the CR you want.
So you can just pick up some LS1 pistons and rods and they drop right into the 5.3 (bored of course)? Stock 5.3 crank is fine? Trying to get an idea of a build for next summer. I was planning on just doing pistons with no major overbore but this sounds like a good idea too for a N/A setup.
2000 GMC Sierra 5.3L 4x4 ECSB
Get the crank from the LS1, also, or plan on having the rotating assembly balanced.
* 2002 Chevy Silverado RCSB w/ 4.3 to 5.3 swap
Installed: McGaughys full 2/4|HD hood/Z71 Airdam|Circle D Built Trans & 3200 stall|34" fans/radiator|True Trac w/ 3.73s|V8 Swap w/ Milled Heads and Comp valvetrain|Custom Grind 22x/23x Cam|Pacesetters LTs & ORY|Magnaflow|Wheatley Tune
Future Mods: Paint (Sunset Orange Metallic), milled 243s, possibly a 6.0 with either turbo or procharger
* 2008 GMC CC Texas Edition: stock with CAI
