Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 72
Thread: Timing retard trick
    Round Rock, TX
    Timing retard trick
    Ok I am seriously thinking about doing this in the near future. Looking for input from anyone with any experience with this. Basically you wire up a seperate circuit for the IAT sensor, you flip a switch and it bypasses the IAT sensor to whatever ohm resister you put inline to trick the computer to think its a different temp air coming in. Then you set that ''X'' table to pull ''X'' timing for the N20. That way you can run max timing all the time N/A till its time to spray someone in ''Mexico'', flip a switch and you have your N20 tune ready to go... Here is a diagram of how its wired in..
    Nov 2006
    Mesquite, TX
    It works very well and allows you to run a motor tune and a nitous tune, I think the 750ohm is 149* on the iat chart
    Round Rock, TX
    Quote Originally Posted by mean05 View Post
    Is 149 a safe one to use in TX...I think 130 is the hottest I've ever seen on the interceptor. Here is a link that I found with more info on it...
    Roberts Nitrous Service - NITROUS WIRING (schematics)
    Nov 2006
    Mesquite, TX
    Quote Originally Posted by DBRODS View Post
    yeah if you see more then 130 then you need to figure out something else to do for a CAI lol. I have a friend here that makes them sometimes, always wanted to have him make me one but never cared to worry about it, i race on bottle way more then motor
    Birmingham, AL
    I figured you had just come up with a way to see how fast Tyler did something...
    But this is cool too! I'd be interested in trying it
    01 Silverado
    sweet deal might have to look into this.
    Plainfield, IL
    couple things.
    1) don't forget resistance in wires of circuit
    2) resistors are normally give or take 10%, so you can't JUST set that resistance/temperature, you'll need to do a values from table above/below the actual resistor being used
    3) a tuner might step in here...but i BELIEVE if the computer reads values that don't make sense with the other sensors, it'll bypass that one sensor.
    i know a lot of guys in my last forum used to put resistors inplace of iat sensor to always get a few degrees without a tune. After a while, the computer just ignored the value, and used a default. Wouldn't want it to do this mid spray.
    I actually have mine run in series with the iat, so that the computer thinks its like 30* colder then it actually is...you might be able to do something with that, and just use an EXTREME.
    i would think that there would be a way to have a push button go to some pin, and have that change the tune. The grand prix guys all have it, a 'normal' and 'race' setting...as do most diesels, but i haven't looked into tuning these trucks much.
    Round Rock, TX
    couple things.
    thanks for the heads up....I actually have a degree in electronic engineering so the wiring is no big deal, if I can remember how to turn on a meter...
    This trick has been around for a long time...
    Im using a SD tune so thats all the computer has to go off of...
    Jul 2009
    Council Bluffs, Iowa
    I've had a Crane TRC-1 Timing Retard Control on my Mustang for years that does exactly what the OP wants, at least in my application.
    I wired the activation of the TRC-1 directly to my Nitrous button, which is on my Hurst T-handle (I ditched the WOT micro-switch). Bingo, the engine runs at normal timing for normal driving, but when you hit the Nitrous button it pulls however much timing you have the adjustment knob set for.
    My only complaint with the TRC-1 is that the markings around the control knob are somewhat vague on exactly how much timing is being pulled out, so I erred on the safe side.
    I've had this thing in my car for probably 10 years or more, so I'm not sure if they even make it anymore.
    I just found a listing for the TRC-2, evidently a newer version of what I have:
    Crane Cams 6000-6425 - Crane Timing Retard Controls – SummitRacing.com
    The markings around the knob of that one are more precise than my TRC-1. That should do what the OP of this thread wants IMO.
    *edit* hmm.....the listing says it hooks into Crane's HI-6 series of ignition boxes. While I DO have a HI-6 on my Mustang, I don't remember hooking the TRC-1 up to it. But it's been 10 years or better, my memory could be off.
    '02 Avalanche 1500 Z-71, BFG All-Terrains, K&N FIPK, Superchips tuner (Nelson eventually), 750-watt Alpine stereo W/ JL midgate Stealthbox.
    '88 Mustang GT, 400HP on motor, T-56 6-speed, 3.73s, 150HP NOS
    '89 K5 Blazer 1500, blown motor and transmission. Another project some year.
    '95 Polaris 600XCR snowmobile, pipes, heads, bored carbs.
    So this is your grand scheme to run both tunes at once, and get the most power out of both..
