Results 1 to 10 of 14
Thread: tahoe
    Oct 2008
    Houston, TX
    tahoe
    Lsd differentials? Is that true or false
    Airaid, alpine double din,
    Depends on how it was optioned from the factory...
    Plainfield, IL
    Believe most of the 4wds were...
    Oct 2008
    Houston, TX
    O ok got a budy who claims all tahoes r n he is thinking about switching his out for a tahoes he has a tru trac so I told him ill buy his tru trac off him lol
    Wasilla, AK
    G80 was an option, not standard equipment. Doesn't matter if 2 or 4 wheel drive, still an option. Have him check his SPID label in his glove box.
    Spring, Texas
    Quote Originally Posted by chuyr View Post
    ...he is thinking about switching his out for a tahoes he has a tru trac so I told him ill buy his tru trac off him lol
    Sounds like a real bright guy...
    Plainfield, IL
    tahoes had a slightly different setup in rear. Sway bars, etc. Not 100% sure it's a direct swap.
    Oct 2008
    Houston, TX
    Well he has money 2 spend so ima just wait n c wht he does is there a g80 for the silvy or has anyone heardof spider gears my friend mentioned it once 2 me didn't understand the concept of the spider gears with locker
    Yep there is a G80 for the Silverado, it gets called a G80 because that is the code that is in the glove-box saying you have a LSD
    The original Eaton posi-traction diffs have spider gears. The 10.5" has a weird 3-pinion set-up.
