Results 1 to 9 of 9
Thread: 2-3 shift clunk after transgo
    Dec 2003
    Is anyone else experiencing this with the transgo kit under almost none to light throttle? It didn't do this before the shift kit. Now it has a loud clunk with the 2-3 shift, but only under none to very light throttle.
    2003 Arrival Blue Silverado SS.....I just can't leave $hit alone.
    Apr 2003
    Mansfield, Texas, USA
    My 2-3 is mkay. Maybe you have a slip yolk in need of grease?
    did you maybe forget a check ball or drill out the wrong passage in the seperator plate?
    Dec 2003
    I checked and double checked and triple checked everything on the install. It doesn't do this under acceleration. It only does this when i'm coasting at low speeds with little or no throttle.
    Dec 2003
    Ok, maybe the shift kit's harder and faster shifts are making the yoke pop now? Hell, one thing i've learned about vehicles is that anything is possible. How do I go about greasing the slip yoke.......and where exactly is the slip yoke (don't laugh, i'm a total amateur at this tranny stuff)?
    Apr 2003
    You gotta pull the driveshaft. Then use some thick grease on the yolk and on the output shaft. I think GM has some special syn greaze. That's about all there is to it.
    Could also be your front driveshaft clunking about too when in 2Hi...
    Dec 2003
    Isn't there a nickel plated one that is supposed to stop this? If so, how hard is the slip yoke to change out?
    Apr 2003
    There sure is, apparently some TSB about it. It's like $50. Drive shaft comes out, remove u-joint, toss old trans yolk. Install is reverse of removal.
    Dec 2003
    Originally posted by Hit Man X+Oct 7 2004, 07:54 PM--><div class='quotetop'>QUOTE(Hit Man X &#064; Oct 7 2004, 07:54 PM)</div>
    <!--QuoteBegin-yeary01z71
    Isn&#39;t there a nickel plated one that is supposed to stop this? If so, how hard is the slip yoke to change out?
    There sure is, apparently some TSB about it. It&#39;s like &#036;50. Drive shaft comes out, remove u-joint, toss old trans yolk. Install is reverse of removal. [/b]
    I&#39;m really thinking this is what it is. It does it also on the 1-2 shift, but not as loud. I called a local stealership and the only slip yoke the parts guy listed in his computer was &#036;227 , can I just try a bearing grease or is there a certain type of grease I should use???
    2003 Arrival Blue Silverado SS.....I just can&#39;t leave &#036;hit alone.
