Results 1 to 9 of 9
Thread: F1 Procharger 2000 Ext/Cab 4x4
    Just thought i would give you guys a heads up on our latest build what we are building. Were almost finished with the project.
    2000 Chevy Truck 4wd Extended Cab w/ 8" Lift on 36"s
    Project includes
    -6.0L Iron Block
    -Stock Stroke
    -4.030 Bore Diamond Pistons
    -Lunati I Beam Rods
    -Blower Cam
    -Patriot Stage II Heads
    -Arizona Longtubes
    -Studed & O-ringed block
    (F1 Procharger w/12 PSI of boost) 3 Core Intercooler
    (Fuel System)
    -Areomotive 500GPH Fuel Pump & Regulator
    -1/2" fuel line 8AN from the bottom of the tank to the motor (3/8" Line to each rail)
    -65 lb. Precision Injectors
    We have had it to together once before. The motor spun the crank pully as well as lifted the heads with the heads torqued down to 85lbs. So now we gave the bearings a little more clearance keyed the crank pully and o-ringed the block & heads using copper gaskets. Hopefully the heads stay down. It diffinetly had a ton of power though. Watching the Speedo at 40MPH we stood on it and it broke the 36" tall tires loose pitching it sideways.
    Although it is mainely a sand dune toy I would like to get some times and dyno numbers on it before it goes.
    Pics and Videos Soon
    Sean
    WOW, Sean,
    that sounds like one badass project truck. When will it be done and what kind of numbers are you expecting?
    thanks for the update,
    allen
    Color me green with envy. That sounds like a load of power in the engine. I can't wait to see the dyno numbers posted.
    Jun 2004
    george west texas
    yea...check that..lifted the heads..damn
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    It willl be done in a few weeks. We are just waiting on the machine shop, rings, and headgaskets. Fuel system is complete as well as everything else.
    Apr 2003
    how did those patriot heds treat you? I've been reading about some apparent quality issues (flatness/true surfaces) with them lately.
    Andrew
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
    We have run a coupple of sets without any problems. I dont know if we have gotten lucky or if they are really not to bad.
    Got some pics for you guys (Link)
    Mar 2004
    Springfield
    That's one hell of a motor!
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
