Results 1 to 10 of 12
Thread: Components Up Front
    Components Up Front
    Im putting in a JL 6.5 component set up front. This is the bottom of the barrel one they make with an in line crossover for the tweeter. Now JL recommends you hook up the tweeter off the midrange. However the factory tweeter and woofer have seperate lines. How exactly should I hook this set up? I have a good deck to power the set for now. Here is the set I have.
    JL Audio: Products
    Stillwater, Ok
    use the factory midbass power wire to the mid, then to inline crossover, on the way to the tweeter.
    Don't use factory tweeter line.
    2003 SLT Yukon, KMC SS 20's, Nitto 420, Flowmaster exhaust, Eibach 2/3 drop, HID's, AEM CAI , Custom Flames from Godspeed Customs, Corvette servo
    Augusta, Ks
    +1
    A deck will be ok but a highs amp is where the moneys at.
    2004 Buell XB12s
    Wichita Falls, TX
    Quote Originally Posted by WARLOCK View Post
    +1
    +1 on what he said, if you are hooking components up to a factory or even aftermarket deck you aren't accomplishing much. Remember, too little power can kill a speaker just as fast as too much power and distortion.
    +2 on not using factory tweeter or tweeter wiring.
    Thanks guys. My source deck is an older eclipse 5442 5 volt. I have the components in and they sound great. One quick question as I found some conflicting info: what are the colors for the front right speaker? Dark green + light green - ?
    Thanks!
    Wichita Falls, TX
    dark green - light green + but it shouldnt matter as long as they are in phase
