Results 1 to 10 of 20
Thread: help! 5.3 swap not running
    ontario, Canada
    Unhappy help! 5.3 swap not running
    I just swapped a 5.3 into my 94 obs and it won't run. it fires up then shuts off right away. i don't have any o2 sensors hooked up yet, I'm not sure if that could be an issue. Does anyone have any clue what it might be? or what I should look at.
    Dec 2008
    san antonio TX
    it sounds like the VATS are not disabled.
    VATS is still enabled in the PCM. You have to get someone to turn it off.
    ontario, Canada
    what has to be done to shut them off. can i use a tech 2 or some sort of tuner?
    EFI Live or HPTUNERS
    whats vats?
    vehicle anti-theft system
    VATS is chip key. You need PassLock disabled in the tune.
    Can i use the trialversion of EFILive to disconnect VATS??
    Feb 2009
    mississippi
    gas iv seen you post this like 8 times and your right vats is chip key passlock is what we have but in hp tuner and if im not crazin i think efilive calls it vats thats why every one calls it vats
