Results 1 to 10 of 11
Thread: code reader
    College Station, TX
    code reader
    can i buy a code reader that places like autozone and advanced auto use?
    also, can those things clear codes as well, or only read them?
    i know they're pretty expensive, like 1k or something from what i heard
    Aug 2005
    St. Anthony, Indiana
    you can buy them from $30 on up.
    Aug 2005
    A code reader is useless without proper diagnostic information, knowledge, and equipment. Don't pay much for one.
    College Station, TX
    ok well lemme say why i want one (its actually more for my dad)
    we have been having an ongoing problem with his emissions codes coming up. if we can reset it every time he gets an inspection, it will be alot cheaper than trying to get it fixed every year.
    Spring, Texas
    I may be wrong on this but even if you reset the emission codes, there are monitors that still have to be reset. I think the only way to reset them is to drive so many miles at certain speeds. The only thing the scanner will let you do is clear the check engine light but the monitors will still be tripped and seen by the inspector. Hopefully someone else can chime in and correct me if I'm wrong.
    yeah, OBDII inspections require about a 50 mile drive cycle after clearing codes before the emissions inspection will pass.
    Apr 2005
    Ugh. You are correct Red. I vomit thinking about trying to get my truck to pass for over a year.
    Good luck my man.
    Gone, but not forgotten!
    This is true. Time and distance (as well as number of cold starts and drive cycles) makes a difference on when the IM flags reset.
    Houston
    Get HP tuners, if you really want a scanner that bad might as well and get a tuning program while your at it, its all in one!
