ever since i put this thumper cam,my brake pedal gets hard sometimes,i almost ran a stop sign yesterday and hit a car,damm pedal was real hard.it goes and comes.is it cause the vacuum and idle??
you need to go hydraboost due to lack of vacuum.
That's wierd because mine did the exact opposite after my cam. I got a vacuum gauge and it went from 22-24 at stock to about 12-15 now (at idle). I hardly have brakes because of it. I'll try searching and see what I can find out.
Mike
2000 RCSB
The vacuum is what makes your pedal feel softer, it assist's in pushing the master cylinder in when you press the pedal. If there isn't enough vacuum to assist then the pedal feels hard and is alot harder to press due to the booster not helping out...it's like having manual brakes.
no way i dont want to switch to hydroboost ,i rather switch the cam lol
if i were to do hydrooost,cause i mite if i wanted to bag it,but i would need all the components from a 2500 right??
[Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
