Results 1 to 10 of 22
Thread: Hey Nelson
    Collin County
    Hey Nelson
    what should timing be set at with a scanner on a 1997 c1500 5.7 350?
    Quote Originally Posted by MrEd View Post
    At what rpm and throttle position? It'll vary quite a bit.
    The question and answer may not match here.
    If it's an R 350 (stock type) timing is not adjustable by turning the HVS like an old distributor. Timing can only be changed in the 'puter. Twisting the HVS will only throw off the CMPS and the offset.
    If that's what you meant in the question, I apologize.
    Collin County
    man i am just trying to figure out why in the hell my truck is detonating, no matter where i get my fuel from. i have even ran a quart of water threw the TB to clean the carbon up and i still am having this issue!!!
    Me thinks you need a pro to actually look at your truck. If you are close enough to Nelson Performance or Gas Guzzler or RedHeartbeat you might try to get them to look at it.
    Collin County
    lets do a refresher here for ya.
    you guys must suffer from some sort of long or short term memory loss.
    bottom line is asked for help GasGuzzler made a nice attempt,Zeake you was saying "take it some where and pay someone some money,to figure it out".
    thats not a option.
    so back to the point before i was rudely interrupted,by what seems to be a few post whores!!!
    my truck has been having some detonation issues,i asked Nelson and he gave me some options to work with.
    i believe my problems is the cats and o2 sensors.
    things are erratic with the truck, so thats my conclusion,to my problems with my truck
    thanks
    Ed
    There is help out there somewhere...
    Collin County
    i agree
    Maybe there's an update for your PCM, like a newer OS or fix?
    Collin County
    newer fix,what the hell is that suppost to mean.
    i finally got a check engine light,says OS failure due to cat.
    so i will proly be getting new y pipe w/cats and buying new O2s
