Results 1 to 10 of 10
Thread: Should I put a LS1 or LQ9 in my 88 Chevy?
    Stillwater, OK
    It has the 5.7 & 5 speed manual in it. Has 188k miles and is getting close for an overhaul.
    Let's assume I already have the LS1 or LQ9, 6 speed trans, clutch/flywheel, & wiring harness. Would it be worth it?? What did you guys end up spending on your conversion? How about swapping out the gauges/cluster & using either the LS1 gauge cluster or LQ9 gauge cluster? And last, where's the majority of the expenses go on the drivetrain stuff (rear end, axles, driveshaft, etc)? Basically, what can I keep & what needs converted?
    Thanks!
    1999 Firehawk 6spd #58. Forged 347 8.7:1.
    2001 Camaro SS. 6spd.
    Jan 2006
    Go 6.0L. They are cheaper and more abundant.
    Jamest
    Quote Originally Posted by candlelit View Post
    Thanks!
    12 Sec. Club! SOLD
    SOLD***
    Stillwater, OK
    yeah I'll probably end up getting the LQ9 if I decide to go through with it
    Your Moms House
    LQ9 FTMFW More TQ also
    College Station, TX
    Lq9 Ftw
    if it were mine it would have a 6L or larger in it already but with a 60e, never a manual shift transmission.
    Ell ess nine F T M F W !!!!!!!!!
    DFW, Texas
    A 6.0l would be alot more beneficial in the end.
    *current* 2001 Chevrolet Silverado Ext Cab -The 6.0l project
    *current* 2008 Chevrolet Silverado Ext Cab
    *retired* 2000 Pontiac Grand Prix GTP
    *retired* 2000 Chevrolet Camaro SS
    *retired* 1971 Chevrolet Camaro Z28
    Pittsburgh, PA
    ugh, 6speed trucks
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
