Results 1 to 9 of 9
Thread: 4.8 to 6.0 swap flexplate
    Feb 2008
    my 6.0 had a flywheel with a clutch when i got it....im keeping it an auto for now so will my flexplate off the 4.8 work on the 6.0??
    also im pretty sure the harness is exactly the same right?? and i have a computer for the 6.0 which will help it run a lil better but its not gonna matter much with the cam and heads and ****...any help will be appreciated
    04 RCSB- 4.8- bolt-ons..nuff said
    carbs are for salads and lawnmowers,
    i was tol it will work on mine, the engines are internally balanced. the harness is the same, and I would still swap your 6.0 computer in. I'm not into tuning, but to me it seems that it would be easier to start on a 6.0 base. and if you drive it at all before you tune it it will run FAR better then the 4.8
    s10 with 4l60e and cammed 5.3 on the road!THREAD
    "People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf.".
    Oct 2007
    Manchester, NH
    Your 4.8 Flexplate will bolt up to your new 6.0 just fine. Just buy new 4.8 flexplate bolts, or reuse the old ones.
    -Derek
    www.GiffinsPerformance.com
    1989 GMC Sierra
    5.3 Swap, Z06 Cam, Z06 Valve Springs, NX Express 150 shot, Giffin Performance Custom Front mount turbo kit, MPT70 Turbo, HP Tuners, Meth Injection, 4L80E with transbrake, 3" exhaust, 3.08 gears
    Turbo Build Video
    ... if you have a 2002+ 6L engine. Measure how much of the crankshaft sticks out from both engines. If they're within a 1/16" then you're good to put the 4.8 flywheel on the 6L engine. If its got about 1/2" difference in length between the two you have an early model, 1999-2001, engine and it won't work. The LSx style 300mm 4L60e won't work with the 99-2001 engine.
    Feb 2008
    mines an 03 LQ4 but ill check either way! thanks alot man!
    Oct 2007
    Manchester, NH
    You just need the 1/2 spacer that GM puts between the crank and flexplate. Some 4.8 had this spacer already installed.
    -Derek
    1989 GMC Sierra
    Turbo Build Video
    You cannot put the spacer behind a Gen3 dished flywheel, it will not let you bolt the transmission in and the starter will not work correctly.
    wichita falls, tx
    a 6.0 computer (pcm) will prob not work, it will prob have a program for an 80e, besides all that if it is the stock pcm from a different truck it will have VATS enabled and wont let your truck start anyways...
    Intro Radicalli's
