Results 1 to 7 of 7
Thread: L92 heads on 6.0
    Saint Marys, GA
    L92 heads on 6.0
    I've been looking at LQ4/LQ9 motors and I was wondering what would be involved in putting the L92 heads/L92 truck manifold on a 6.0? I know the combustion chamber on the L92 is larger the the 6.0 head, so it would probably be better to put this set-up on a LQ9 since it already has a higher compression than the LQ4. That's about all I know.. I'm wondering would my exhaust manifolds on a 2004 5.3 silverado work on the L92 head and would this be a plug and play swap, just like the 6.0? Also, what would be a good cam with this set-up using stock exhaust manifolds?
    truck dbw, do a search on my name or l92 head swap, i done this, i would go with the lq9. being i like compression, but the lq4 is no slouch niether, with a good mill you could have the same compression, cable driven throttlebody's i had to make my own brackets for the cable.not really a hard swap to do just have to have access to making parts. as far as the manifolds, they'll fit, but i would highly reccomend long tube headers..
    Simple: 408 on steroids!
    single digits coming soon!
    I think all you need is the offset rocker arms and the intake/throttle body but someone else knows more than me.
    correct, 8 off-sets and 8 ls rockers, i just used 8 off my other setup!!! def. a l92 intake unless you wanna go l76 or something.. then you'll def. need a custom grind cam
    What are some of your other mods you have now? and/or future mods? If you plan on staying NA, have you thought about some 243's?
    Oct 2008
    Scott, Arkansas
    It's a little more to swap L92 heads and intake than just a good set of heads but I bet it's worth it. First off the intake uses a 90mm TB and it's a better overall head design than the other LSx heads. I read where a guy went from a Radix supercharger kit to ported L92 heads/intake and put in a better cam and gained several tenth in the 1/4. That's crazy going from FI to N/A and gaining. If I remember right he also had Patriot ported 317 heads with the Radix and a cam made for the Radix. I would definately go with the ported heads though.
    Oh and I don't know where you get the L92 having bigger chambers. LQ4 and LQ9 engines (with aluminum heads) have 317s which are 72cc while the L92s have 70cc.
    Saint Marys, GA
    Quote Originally Posted by ss454327 View Post
    You're right.. I must have got the two heads mixed up somehow whenever I was writting this. Anyways, I think I have decided to just put a cam in my 5.3 and play with what I already have in my truck. Thanks for the info though.
