Thread: TC and towing?
    Victoria, TX
    TC and towing?
    I dont think I Really will benefit from a torque convertor right now but later on i plan on cam and heads swap. MY concern is I due a fair amount of towing (10k+) and really need that low end brunt getting off the line with that pig behind me, will a TC cause me problems with that much weight or have any adverse effects?
    Truck is in sig 01 2500hd 4x4 315/75/16 tires
    2011 4x4 6.2 Silverado ltz 6" fabtech lift 20" XD spy 35" nitto mud grappler
    It won't be a problem if you choose wisely. With a standard performance converter you'll probably burn up the clutch towing a load.
    Pick one that has a heavy-duty clutch, like these:
    Yank Performance Manufacturing.
    Aug 2005
    St. Anthony, Indiana
    don't go any bigger than 2600-2800
    Yup--since you are using it for towing, you won't be getting crazy with your cam specs... Since you have a 80e tranny, i wouldn't even do a stall. Just spec something for low end powa!
    I would put at least a 2200 RPM stall in for towing with an 80e to get into the low end of the TQ curve. If not a converter then get a lower planetary gear set put in the transmission for better acceleration from a stop.
    California
    You could also change the differential gears and go a bit lower for the lower end torque that you want and you will end up getting better fuel mileage when towing.
    But it all depends on what you currently have.
    1998 Silverado Z-71 Ext Cab. 5.7L Descreened MAF, K&N direct replacment, 32x11.5 R15 AT's,Posi rear end, True duel w/Magnaflows, Sub woofer setup, Remote starter.
