Results 1 to 10 of 11
Thread: Cam question
    Edinboro, Pa/Ft. Meade, Md
    Cam question
    Ok, i have been doing some research about cams but still need some help, i have read a ton of threads on here and pt.net. trying to find a decent cam to put in the truck. Now i'm not trying to just stuff the biggest cam in the truck i can as i have seen a lot of people ask about or huge gains anywhere. I am looking for something a little better then the stock cam though with a little bit of a lope to it. So i have been on a couple different sites looking and here are some i am thinking about, but i need a little help also, here are some that i think will work for me so far, thanks in advance:
    Cranecams: 1449041
    GOOD DAILY DRIVER, STOCK TO SLIGHTLY MODIFIED 4.8L THRU 6.0L, GOOD FUEL ECONOMY, LIGHT CHOPPY IDLE, LIKES HIGHER ROCKER RATIO, NEEDS NO TUNING - RPM RANGE 1800-6000. 551 / 551 210 / 218 114*
    http://www.cranecams.com/newproducts...8B/PP0808B.pdf
    or
    GM Performance 12480033 - GM Performance Parts Gen 3 Hot Cam Kits - summitracing.com
    or but can't find the specs on this one
    COMP Cams: Thumpr™, 275THR7 <br>High Performance Street, Stock, Choppy/Thumping Idle
    I suggest you don't buy an "off the shelf" grind. Call up Comp Cams and get a custom grind made to fit what you want. =)
    Mar 2006
    Quote Originally Posted by muddychevy98 View Post
    Cranecams: 1449041
    or
    So are you trying to avoid putting a converter in it? Tell us more specifics as to what your looking for.
    i would like not to get a new converter cuz the one i have is new, i toasted the old trans last march. But it's 1800 stall speed on the one i have now.
    My truck is definitely not something that will see the track, i just want a little more power without FI.
    put it on a dyno and see what RPM it start building TQ and get a converter that will get you to that sweet spot.
    Mar 2006
    ok.....Since you dont have much converter, you need to be careful. You could prolly go with the crane you have listed above and still retain your converter. It will want to push your truck some at a stop light because you will be idling faster and such. You can also run the affordable 918 springs with that cam. An off the shelp cam will be fine for what you are wanting to do. You are not going to hear much cam with that one but it is going to make a ton of torque, should make your truck feel really good! Thats what your truck needs, ricers need HP. lol good luck with your swap!
    Quote Originally Posted by carfreak07 View Post
    thanks for the input and torque is always good
    Yeah, the Edelbrock 2216 is too much for your truck with a stock stall. I am going to say the LS6 cam as well. Or go have a cam custom ground to match up LS6 specs, but have a higher LSA--only because I like a nice lope at idle...
    Crossett,Ar
    From personal experience what you are needing is the TR Old Man Truck cam. It is a 214-220 .600-.523 115lsa. It has great pull down low. It may even pull a bit higher then then stock cams. I know Mine pulls fine up to 6300 when my truck is programed to shift out. May pull higher... I dont know. Thunder Racing claims it has no need for a retune.... I had mine retuned anyway. Its a great mild cam. The only reason I dont like the cam is it TRUELY is a beginner cam. After I got it I started wantin it to be faster.... So mine is gettin snatched out for a bigger one asap. But if a good TRUCK cam is all you want go to Thunder Racing - Performance Parts for your Late Model Musclecar! Camaro, Firebird, Trans Am, Corvette, Impala SS, Mustang, Cobra, Truck, GTO look up your truck go to valvetrain and cylinder heads then to cams and so forth. Im sure you will find it. On top of everything else... it does keep great gas mileage.. I even had a bit of increase.
