Results 1 to 7 of 7
Thread: Lt's Headers bolts..
    Feb 2008
    Arizona
    Does anyone know where can I find a nice set of bolts for my headers? Cause I am going to install them soon and I dont what to use my factory ones cause I've been told that the dont hold for too much.. anything else anyone would recomend for my install? any link would be appeciated!
    Thanks!
    06' Silverado RCSB 5.3L 4wd..
    HID's Hi, Lows & Fogs
    WWW.ARP-BOLTS.COM 10MM X 1.5 I believe.
    Feb 2008
    Arizona
    Thanks! just couldnt find the price or anything.. are the ones for "LS based engines"?
    Feb 2008
    Arizona
    anyone else can help me with a link? thanks
    Feb 2008
    Arizona
    really? arent they suppose to break??
    S.A. Texas
    Break, I dont think the header bolts will break unless you over torque the crap out of them. I have been running the stockers, I did use a Mr.Gasket brand gasket. I see no need to use anything else.
    I have always used the stock metal 3-layer gaskets and bolts. Just don't torque the hell out of them when tightening and also make sure to tighten them perpendicular to the block...if you try and tighen them at an angle--they will break.
