Results 1 to 10 of 13
Thread: stock 4L80E at 425rwhp ?
    Oct 2008
    Houston
    Been searching and calling around for built 4L60E's this morning.
    Was told at 400+rwhp on 5,000+ lbs Tahoe I will need the billet output
    shaft for my 4L60E. That puts it at a Lvl 5 FLT or Century transmission.
    Both run $2,800+ ......... ouch.
    Saw the 4L60E to 80E sticky ........ doesnt look too hard.
    Have seen that stock 4L80E will easily handle 400-450rwhp.
    Is this true ? $800 stock 4L80E sounds lot better if it really will hold up.
    I've been running a pretty much stock 80e with a 500HP NA enigine + a 125 shot for quite a few strip passes in my almost 5000 lb truck with problems. I cranked it up to 300HP and made about 20 passes before the stock forward sprag gave way.
    Oct 2008
    Houston
    Yeah, but I'm not going to be EVER doing ANY launches at the track
    much less on gas which really shock loads the crap out of everything.
    The 80e should last the life of your truck, then.
    Jun 2004
    george west texas
    yep
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Oct 2008
    Houston
    Thanks guys,
    Right now leaning towards finding a 4L80E in local junkyard
    and just putting a shift kit and new converter in it.
    Oct 2008
    Houston
    Gonna hit 10psi and 400-425rwhp with this car, thats it, never going to
    "turn it up" or get crazy with this build.
    No hard launching at the drag strip
    No extreme towing
    Just some quick street fun. I have hot rods when I feel the need for speed.
    Suggestions on building my 4L60E for $1,500 and hold that power. ?
    Who to use ?
    It's not a direct swap but I'm sure you saw that if you read the how to. In your case I'd go for a built 60 but that's only because I'm cheap, would already have the 60, and could build it myself.
    Oct 2008
    Houston
    How hard is it to rebuild an automatic ???
    I see the rebuild kits and shift kits for just a couple hundred bucks.
    Autos scare the shyt out of me though. Sooooo many little parts
    Oct 2008
    Houston
    I found some links worth sharing
    Back to thinking on buying $700 in parts for HD 4L60 rebuild by local trans shop.
    ebay seller with all the HD internals for a stage II-III rebuild for
    about $600-800 in parts.
    eBay Store - Procare Performance Transmissions: 4L60E 4L65E 4L70E TRANSMISSION: TRANSMISSION CASE SAVER 4L60E 700R4 TH350
    Add this guys $550 billet out put shaft for a stage V build
    Circle D Specialties - Billet Parts
    His 4L60 rebuild kit has everything for a Stage IV build up.
    Circle D Specialties - 4L60E Rebuild KitKit
