Results 1 to 10 of 31
Thread: 4.8L to 6.0 Swap I searched but no....
    May 2006
    Waco TX
    Its a 2006 GMC w a 4.8L and he is wanting to do an LQ9 swap. Correct me if im wrong on these
    1. A LQ9 would be an easier swap because he has a 4L60e and the lq4 was mated with the 4l80e.
    2. Will everything swap right over? Engine Harness, fuel lines, engine mounts? I believe they will all work right?
    3. This should be a fairly easy swap right?
    Mar 2006
    Phoenix, AZ
    Quote Originally Posted by Red03SilSS View Post
    1. The only difference between transmission types is the flexplate and spacer. You can do either - just put your original parts on the new engine.
    2. Use all your stock accessories...they will all swap.
    3. Pull out the old one, swap over any parts that are not the same, drop the new one in, tune, and go. Very simple.
    2006 GTO M6 Brazen Orange
    2006 Silverado CCSB Duramax
    Be sure to get a 2002 or newer 6L to get the LS1 size crankshaft end. The early models had a longer crank and requires a flat flexplate, not dished. Also, double check the bolt pattern of the flywheel to the converter before it goes in the truck, if you have to rework the holes in the flywheel to mate up to the converter, its so much easier to do out of the vehicle. That or just use the flywheel off the 4.8L engine.
    Mar 2006
    Phoenix, AZ
    If he's getting an LQ9 like the original post said he won't have to worry about having an old style engine with the longer crank snout.
    Gotta update the tune, too.
    wichita falls, tx
    should be easy, just use the 4.8 flex plate, front drive acc and harness and put it on the 6.0 and shove in the truck and
    Intro Radicalli's
    May 2006
    Waco TX
    OK it seems like it would be fairly easy, next question.
    Anyone know where I could get a used one? My friend has the money and is dead serious.
    PM Kurt and get the # of the salvage yard that he's all the time saying has 6.0L engines for sale. You might call Hi-Way Auto and see if Austin has one, too.
    Apr 2005
    +1 on that. Kurt knows these guys, and I got a hella deal on my 6.0 & 4L80e, complete with all accessories and harness. Hell, I even got the factory airbox with a K&N already installed!!
    EDIT: I just replied too late on this one! Sorry Daniel.
    Gone, but not forgotten!
    May 2006
    Waco TX
    OK if we were to do an lq4, what all would need to be done for the tranny?
    I found this?
    eBay Motors: 03 04 05 06 07 Hummer Yukon Suburban Engine 6.0L Motor (item 200260642694 end time Nov-04-08 14:11:12 PST)
    intake manifold off the 4.8 woud work right?
