Results 1 to 10 of 16
Thread: 90mm TB & intake with wiring harness adapter
    Apr 2005
    UPDATE: Used 90mm intake from a GTO. All rails, injectors, sensors, gaskets, etc. included. Also included are brand new intake bolts and a new TB gasket. I also have a wiring extension for something I bought from Katech, but I can't remember what sensor it went to. $150 OBO
    90mm TB & harness are sold.
    Gone, but not forgotten!
    tell me your upgrading
    Apr 2005
    The extension wire should be for the MAP sensor since its now at the front of the intake behind the throttle body on LS2 intakes.
    Apr 2005
    Thank you sir!
    Nov 2006
    Mesquite, TX
    you dont have to have the extension...there is enough wire in the stock harness to easily make it work...
    man if you want to sell the 90 and harness i would be very interested FYI
    Apr 2005
    Quote Originally Posted by mean05 View Post
    Oh well, I already have it.
    I would like to try and sell together first. Send me a PM on what you were thinking though...
    I'll give you free retunes!
    Apr 2005
    I thought I had those already?????
    Spring, Texas
    Anyone know if this will be a direct swap with my stock set up and 42 lb injectors?? If not, what else would be needed??
