Results 1 to 9 of 9
Thread: Clunk
    Grand Rapids
    Clunk
    I did a break stand the other day and I heard a clunk from underneath. Today I got on it from a stop light and I heard it again, Its like there was a little pause and then hit. Could it be the U-joints or the tranny. It felt like a U-joint but not sure.
    04' silver,RCSB,volant intake,jba catback, 2" shackle kit,vette servos,
    sounds like a U-joint, doe it do it when you put it into gear?
    Simple: 408 on steroids!
    single digits coming soon!
    Grand Rapids
    I dont't notice it if it does. If the U-joints are bad you can usally test it by turning the driveshaft back n forth to check for slop correct? Do they make beefy u-joints?
    Last time I heard that it was axle wrap up. Look for damage on the bolt heads and rear driveshaft yoke area. The springs end up wrapping upwards and the pinion tries to point upwards when you brake stall like that.
    Grand Rapids
    How do I correct the situation? If nothing looks wrong, what can I do to avoid this from happening. I looked up traction bars and I didn't see anything for 2wd trucks. And if something looks twisted how do I get the correct angle? What does everyone else use to avoid this from happing?
    Caltrac bars from CalvertRacing.com
    Jan 2007
    Burleson,TX
    do you have a shift kit installed?....also is your truck stock height?
    06 silverado CC Volant CAI/ Corsa Sport exhaust
    dynatech supermaxx headers/cats
    LPE GT2-3 cam/ Comp 918's/ Rods
    Eaton LSD 3.73's
    IAT Shocks
    DANNY TRANNY w/2800 TCS billet verter
    275HP and 293TQ Pre Cam
    314HP and 303TQ post cam
    Grand Rapids
    Quote Originally Posted by nonecktribe View Post
    No shift kit. Stock height
    Racoon Twp., PA
    Stop and pulling out, then it does it? Try lubing up the slip yoke on the splins.
    2013 CC 5.3
    81 C10 LS1 project
