Results 1 to 10 of 13
Thread: i smell oil!
    Jun 2007
    i smell oil!
    ok i have breathers on my pvc and valve cover cause when i get into boost hard i was getting oil in my intale ,hence fouled plugs smoke etc.the problem im having is that whenever i come to a stop i get alittle condensation smoke and i smell oil ,its definately coming out of the breathers i can watch the vapors come out of the breathers.does anyone have this issue and how can solve it?
    Jun 2007
    cmon red i know youre out there.lol
    I can't smell mine, but I have to passenger covers that have oil filler breathers.
    Jun 2007
    i also dont have any baffles cuz i cur them out for my roller rockers.i wonder if this has any bearing on it.i actually get alittle like idk if its smoke or condensation coming out of them but i see it and smell it.it makes my feel like im driving a pos.when i come up to red light or stop.i dont think its anything new because its done it since i installed the breathers.i wonder if a catch can setup would help.
    I don't have FI so I don't have any real life experience with that subject. I have a breather on the driver side and I still pull vacuum from the driver side and the valley cover using an LS6 cover plate.
    Jun 2007
    ooo you had to get fancy on me huh ,i thought u just had the same as me.im wondering wth is causing this its pissing me off.everyone said just through a couple breathers on it .ye it solved 1 problem but created another.go figure right.?im thinking about changing my valve covers back to baffled 1s.i dont have the roller rockers on it anymore ,i hated the noisy bastards.
    LS6 valley cover will most likely solve your problem.
    Apr 2005
    I put a catch can inline and ran the factory system. I couldn't stand the oil smell.
    Gone, but not forgotten!
    Jun 2007
    hey sc ,could you clarify a little bit on exactly how you did it ?and what do you mean by you ran the fac. system.the smell is killing me.what process did u use etc.so its not just me ,it does happen?
    Mar 2006
    Mesquite
    Quote Originally Posted by SCIV View Post
    Same here. I have the catch can and get the oil smell in the cab. I guess it's just a negative side effect if you vent it into the air instead of into the intake. I think I'm going to try mounting the catch can in the front down low. That will hopefully 1.) help the blow-by oil or whatever to run down to the catch can easier, rather than pushing it through a 3/8" hose and 2.) hopefully suck the air under the truck and dissipate it a little. We'll see.
