Thread: marine inj.?
    Jun 2007
    marine inj.?
    what is the difference between marine injectors and regular automobile/truck injectors?ill gt deeper as soon as i know the difference.i was told just the internals were made of brass.
    Jun 2007
    any one ,this is pretty important that i find out.
    Jun 2007
    bump me
    Oct 2007
    connecticut
    bump
    02' silverado ext. cb 2wd , 5.3 liter 325c.i. LM7, ported and polished throttlebody with bypass, Jannetty Racing 87 octane dyno tune, cold air intake with custom ram air, Heavy duty built 4l60e with vette servo, Z-pac clutches, "The Beast" Sunshell, transgo shift kit, yukon 4.10 gears with true trac, custom exhaust with Moroso Spiralflow, no cats, MSD 8.5 race wires, NGK TR55's
    Damn dude, take it easy on yourself during personal wacky time lol.
    Sometimes it can get out of hand
    Satan just called - hell froze over.
    I take it like a virgin on prom night... I'm not happy, it hurts, but at the same time, I'm too drunk to care.
    May 2007
    Elmira
    different flow rate. The marine injectors are 42#. The regular truck injectors are 32 or 36# I believe. Just more flow from what I've been told. I've been looking around for bigger injectors myself.
    2000 Silverado RCSB 6.0 swap, 5 speed, Nelson Tune, Pacesetter LT's, no cats, 228r cam, CAI, 3.08 gears (3.73's install this winter hopefully).
    The flow rate of injectors is somewhat dependent on the allowable psi that is governed by the FPR. For marine applications, the injector rating is determined with the standardized 43.5 fuel psi. So by the way of a lower fuel pressure rating at the injector nozzle, a marine injector is typically rated lower because they are based off a lower fuel psi. If you take the same injector and put it on one of our trucks, they will flow better when operated with the 58 - 60 psi the stock LS truck regulators put out. I am not sure, but the marine injectors may also have a different type of pintle style for their spray pattern...Single pintle style is one I know of, and another is a multiple pintle style with a good atomizing spray pattern. Some injectors spray different angles of degrees, different patterns of atomization, etc. So, typically, if you take a 30 lb.p/h truck injector and match it up against a marine injector ratred at 30 lb. p/h, then the marine injector will flow better because it was rated at a lower fuel pressure...the 30 lb marine injector would flow at about 34-35 lbs. because of the higher 58-60 fuel psi of the truck FPR vs. the 43.5 psi standard set for marine applications...
