Thread: Help with Transmission Shift Linkage
    Apr 2006
    Muldrow, OK
    I am wrapping up my 5.3 swap in my 1993 OBS (FINALLY)....and just got stumped with my shift linkage. I used the S&P style motor mounts and it moved my tranny back about 1 inch. I didn't think this would be an issue because I figured the stock linkage to the 4L60E would allow for this additional reach. I was correct, but what I didn't figure on was the addition of the Shift Selection Module on the side of the transmission. It is the black box that tells the computer what gear the tranny is in. The linkage hits it solid and will not allow it to rotate. Two questions:
    Do I still need this box? (I think all it does is not let my truck start if its any other gear besides park)
    Can I adapt a 96 up shift linkage to work with my 93 column.
    I appreciate all the help.
    Thanks,
    Cody B.
    -Slow Is Not An Option-
    93 Stepside - Forged 347 - LS6 intake - Stage II LS6 Heads - MTI X1 Cam - Vigilante 2800 Stall - HP Tuners - Schoenfeld Headers - 4.11's w/Powertrax - Caltrac's - 430/400
    02 Trans Am - Forged 408 - Single Plane GMPP - 96lb/hr Injectors - HPT 3 Bar - Twin 67mm Turbonetics - Huge FMIC - Moser 9" - 4L80E - Alky Control Meth - Jesel J2K - Eboost2 - waiting dyno
    remove the module and remove in the PCM the PRNDL option. You should not have any issue with the selector. Is the arm pointed up?
    Apr 2006
    Muldrow, OK
    Cool....thanks for the info Red...
    You're the man...as usual
