Results 1 to 10 of 11
Thread: 4L60e swap questions.
    I have a 98 OBS truck with a 4.3 vortec. I just purchased a 03 5.3 engine for it. My current drivetrain has a 4L60e from the factory? will I need to install adapter plates to make that transmission work with the new motor? I have heard both ways I just want to know for sure. and if so where can I get the plates that I hear about?
    Josh
    Yes, you will need the spacer and longer bolts or hughes makes a converter extension to slip over your factory torque converter to the crank.
    which is better and where can I get them at?
    either is fine, i prefer the extension and longer bolts available from GM dealers such as CrateEngineDepot.com or SDParts.com
    I went there and found this
    Transmission Adapter Kit 19154766 - Crate Engine Depot
    But it seems to be the reverse? is this right?
    Josh
    May 2007
    Las Vegas, NV
    Quote Originally Posted by hellfire_studios View Post
    Josh
    That would be needed to put a trans that was behind a GenIII motor behind a GenI motor, so yes the reverse of what you're doing...
    You need this
    LS1 Flexplate Spacer 12563532 - Crate Engine Depot
    and these
    LS1 Flexplate Spacer Bolt 12563533 - Crate Engine Depot
    I reused the the stock flexplate on my 6.0L (same as 5.3L).
    Thats it
    how many bolts?
    Six.
    May 2007
    Las Vegas, NV
    how many bolts?
    count the holes
