Results 1 to 9 of 9
Thread: LS1 Short block swap??
    Feb 2008
    Gainesville, Fl
    Ok guys i want to do a ls1 short block swap. From what i know its pretty much just bolt in and tune. Is there anything i should look out for? Can i retune my pcm or do i have to buy another? Another question is does any one know where i can get a fully assembled and balanced short block from someone fairly cheap? Thanks guys give me any advice on this swap.
    04 Silverado RCSB
    02 LS1 Shortblock(Stock)
    LS6 CAM - 204/219 .551/.548 117.5
    243 Heads w/ Light Weight Valves
    Exhast- LT Pacesetters w/ory, 3" Straight pipe
    Suspension- DJM 4/6, Doetsch Shocks, Caltracs
    Need a ported DBW TB > http://www.ls1truck.com/forums/sale-...ale-trade.html
    LS1 swap is just remove and replace one for the other. The PCM can be retuned for the additional displacement. You can get a built LS1 from all kinds of places, just look around your local area first. SDParts.com is where I would buy mine in Texas, or Texas Speed and Performance. I would opt for an LS6 or 2002 LS1 block if possible, better construction.
    Feb 2008
    Gainesville, Fl
    Hey guys im pretty sure this a good deal but i want to make sure. I just found an 02 ls1 ss camaro engine with 36k for 1500$ plus shipping. This includes all the sensors, fully assemble heads, all covers too just no intake. Is there anything else i should but for the swap? Ive never done a engine swap before ether but i have done like 4 cam swaps and 2 heads swaps. So i should be pretty capable of doing this right? Any one helpful information will be apprecated!! Thanks Brandon
    04 Silverado RCSB
    Yeah, I'd say thats a really good price for that low of miles.
    Just write down what you take off and in what order as you go along and you'll have no problems switching engines out. You'll need to swap oil pans, pickup tube and windage tray, crankshaft pulley and water pump along with all your accessories.
    Feb 2008
    Gainesville, Fl
    ls1tech.com guys thats where that great deal came from!!
    04 Silverado RCSB
    Feb 2008
    Gainesville, Fl
    Im feel dumb asking this but, what is the windage tray and where is it, Im guessing ive probly seen it i just dont know the correct name of it? Also can i still use my stock torque converter or will i have to replace that to? Also could anyone give me an estimate of how long this procedure will take? wanting to do it in two days.. possible? 8 hour days? I do a cam swap(removing the lifters) in 8 hours with breaks and lunch.
    04 Silverado RCSB
    plan 3 days. Windage tray is the metal tray below the crankshaft that stops the oil vapors from getting out of control off the crank as it is slinging it everywhere. Yes, you can reuse the stock converter.
