Results 1 to 9 of 9
Thread: hhheeeellllppp!!!
    Feb 2008
    hhheeeellllppp!!!
    Aloha all!
    small problem with my tbi... on a dead stop or while driving, if i stomp the gas, it will choke for a sec.... everything is stock on it except for intake... any ideas? also, the trans is creating a check engine fault... when the light comes on, the gears hold till 3k then shift real hard like there is a super shift kit in it, and in the 50-60mph range, it wont kick down into overdrive....... when the light is off, it will shift normal... any ideas???
    thanks!!:wtf:
    May 2004
    When did this start, after the intake? Get you a code reader or jumper key from Auto zone to see what code it is.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
    Common problem relating to a bad throttle position sensor. I rarely have found a bad TPS, usually bad wiring. Also check the engine coolant temp sensor.
    Feb 2008
    ahh ok, ill check thoes out... for the trans problem, i think im just going to drain the pan and see what kind of crap i pull out of there... change the filter and that stuffs... see how it works... thanks guys! ill keep you all posted on how it went...
    Shreveport, LA
    Quote Originally Posted by 95 silverado View Post
    Aloha all!
    small problem with my tbi... on a dead stop or while driving, if i stomp the gas, it will choke for a sec.... :
    WHen was the last time you changed your spark plugs?
    2004 gmc sierra No more
    New 2008 Chevy Silverado!!!
    Feb 2008
    Haven't done it since I got it... Couple weeks ago... Sounds like a plan!
    Shreveport, LA
    I had a 95 just like yours and it was doing the same thing! i took it everywhere to see if it was and internal problem but and no one could figure out what was wrong! My dad suggested the spark plugs, I changed them out and never had the problem again!
    Beaufort, SC
    Quote Originally Posted by newchevy View Post
    sigh, let's take a moment for our old friends, whom we both booted for newer fancier friends
    '04 Hemi QC - H/C/I/bolt-ons/tune - Sold
    '70 C10 SWB Stepside - LQ4/4L65E
    Aug 2005
    St. Anthony, Indiana
    A bad tps will cause your trans to shift wierd like that.
