Thread: what size are the fuel lines????
    what size are the lines on the fuel rails on a 2001 6.0 (fittings)
    and what size are the under chassis feed and return fittings at the filter (98 suburban)
    i am doing a 6.0 swap to a 98 obs and need to adapt the fuel lines
    5/16 and 3/8
    5/16 on the rails and 3/8 ar the filter? do you know if the threads are NPT or not?
    The fittings are 3/8" on the pressure side and 5/16" on the return side. The fittings on the filter should be straight thread but I'm unsure of what size they are since I always toss the truck filter in favor of a Corvette internally regulated filter for a single line fuel rail.
    ok thanks
    May 2007
    Las Vegas, NV
    The filter fittings are metric o-ring 14mm x 1.5
