Thread: speed-o OFF
    Oct 2007
    speed-o OFF
    i mean its waaaay off... 20mph at least..
    happened after i put the new stall and tranny in.. 3600 on 2.1 str.
    i have a feeling (dumb) that has something to do with it
    02 Sierra... motorless for now.
    02 SS.. stock bottom 4.8, 241's, 224-220/116+4, 918's and pushrods, front mount turbonetics 78mm, HKS GTII, TiAL, eBoost2, Yank PT3600, Performabuilt 60e, solid motor mounts. Tuned by me with HP Pro and LM2/AFX
    does your transmission have two speed sensors? Thats what it sounds like, like it was an 80e instead of a 60e. It shouldn't change unless you have a bad sensor.
    San Marcos Texas
    If you can read the MPH with a scanner, see if it reads the same as the speedo. It could be that your instrument cluster is off or failing. Maybe you pinched a wire when you installed the tranny.
    Jun 2007
    instument panel as usual in these damn things u mean the around 70k instrument panel?lolya either pinched wire or changed tires in the swap somewere or he tuned his own speedo.lolseriously tho instr,or pinched wire ,check all plugs good.i have plenty of exp with em im on #7 tranny .this 1 is going billet,see what i can brake b4 i go 4l80.
