Results 1 to 10 of 11
Thread: Something interesting about K&N filters
    A good read...
    K&N Mass Air Flow Sensor Test Results
    Oil wasn't found to be a cause of MAF failures, silicone contamination is!
    Feb 2008
    Alabama
    Thats cool and a first I ever heard of K/N being blamed. I just cleaned my filter and thought I had to much oil on on it because it sputter a little but then I looked at the plugs and they were real bad.
    ff_jeff Guest
    I still think its the oil... Funny how it happens right after you put too much oil on the filter, and cleaning fixes it.
    Feb 2008
    Alabama
    How do you clean a MAF? I wanted to clean mine but not sure what to use.
    ff_jeff Guest
    I used carb cleaner, but there may be a better product.
    Jun 2007
    maf cleaner.
    ff_jeff Guest
    there you go!!!!
    Feb 2008
    Alabama
    I asked for maf cleaner at Autozone the guy said you cant clean them are you crazy. So I was going to get electrode cleaner but thought id ask first
    ff_jeff Guest
    autozombie hires dumbasses most of the time... just spray it off and let it dry... Allot of people who work at auto zone are kids or cant do much better, they only make maybe 10 bux an hour. max. electrode cleaner would work but try to find this. http://www.crcindustries.com/catalog...sers/05110.jpg
    Feb 2008
    Alabama
    Cool ill get tomorrow for sure I think ill try advanced auto see what kind of dumb asses I can find there.
