i need a cam install kit and was wondering if anybody in the houston area that works at a dealer can get me the hook up on it?
GM #12499228
sells on gmpartsdirect for $40-42.
GM #12499228
-leo-
2009 Silverado CC - 6.0L L76|6l80e|3.42s|4/7 drop w/ helper bags
01 silverado ecsb - (RIP 04/2009)
Yeah, no need for a cam kit. All gaskets are reuseable. Some people say you don't even need a new crank bolt if you are not FI... But I always use a new one. Go to Sears or O'Reilly's and get a compression tester kit for the compressor so you can air up the cylinders to keep the valves up. And go get the cheapy $7 valve spring compression tool from O'Reilly's while you are there and cut off the upper part of the handle. Use a spare rocker bolt and some spare retainers to gap out the compression tool... It's all pretty easy.
If you do need one..I know a guy who can get it dealer price.
Home
Call the number on there
This copied from GMPD site
DESCRIPTION: GASKET KI LS engine camshaft installation kit LS eninge cam installation kit includes front engine cover gasket, water pump gasket, intake manifold gaskets, valve cover gaskets, balancer bolt, and front seal.
List for 40.xx
Not a bad deal for everything, of course what they charge for shipping might be better to get it local.
they charge 10.95 for S&H and the kit list for 40.56 for 51.1 shipped to me, not a bad deal for the whole kit. Not sure you could get better than that locally, but if so id buy one two for my cam swap.
just get the 3-6 buck crank bolt . . . you don't need everything that comes in this kit for a cam swap.
The most important thing in the swap is the crank bolt.
Mine - 04 Crew Cab Silverado 2500, 6.0L - L92 heads/intake - 4L80e - 4wd
Wife's - 08 Trail Blazer LT - stock - every option - slow !
Vid of my old Silverado 6L <---
99 Fountain - 27ft Fever - 502 mag MPI :-)
i'm hoping that someone local will chime in and get me a price.
'cause i would like to not have to pay for shipping.
plus someone else said that it took too long for it to be shippind from gmpd.
i wonder how much scoggin-dickey sells it for and if they can get it to me faster.
-leo-
next day from sdparts.com to me
