Results 1 to 10 of 24
Thread: TBSS Intake manifold swap
    HotRodV6 Guest
    Has anybody ever thought about doing this? From what i have been reading they will bolt up to the stock heads, and flow alot better than the stock truck intakes, plus they have the 90mm TB opening. And a place in dallas called ADM Performance is porting them out and picking up 10-15 horses on the port job for 200 bucks.
    Im looking at swapping 243 heads and LS6 cam into my 5.3 and was thinking the TBSS intake might be an easy swap to get some more power, plus the bigger TB.
    More air in=more air out and more power.
    Mar 2006
    Mesquite
    Actually: More Air In + More Air Out = More Power
    I'm feeling anal today. I know what you meant.
    I think Virgil is going to try this - you might check with him or I guess he may see the post.
    TMI Moze...
    NJ
    What year TBSS can you use? What mods are required to do this?
    2004 Chevy Avalache Z71
    http://www.cardomain.com/id/Fast92RS
    Apr 2003
    Mansfield, Texas, USA
    Thumbs up
    You'd probably be better off having the heads worked up before going to the other intake.
    Nov 2006
    Mesquite, TX
    i am doing this swap here in the next couple of weeks i already have the intake setup.....they are saying at least 15rwhp from the swap plus if you get the rails and injectors you get a better flowing rail and 33lb injectors......just need to buy the wiring harness adapter for the injectors and eletronic throttle body
    HotRodV6 Guest
    Quote Originally Posted by mean05 View Post
    Does the stock DBW TB on the truck use the same connector? I def think this is a worth wild mod, i was watching one on ebay that was complete minus TB and missed it at the end and didnt get my bid in, it went for 160 bucks.
    HotRodV6 Guest
    Ok, well i put up a wanted thread looking for a TBSS intake setup, and got a PM about a guy that has the complete setup, manifold, fuel rail, inejctors and TB, he removed it at around 2K miles and installed the maggie.
    The TBSS injectors have a different plug than the truck injectors? If so ill probably sell them and get some 8.1 injectors, that way it will be plug and play on my truck, id rather do that than cut up the harness to swap connectors. I was also under the impression that the DBW TB's all used the same harness plug, but if i have to change it, then i guess i will.
    Nov 2006
    Mesquite, TX
    no they use a diff wire...they sell the new harness on LS1Tech.com for $189...also you would be better running the LS2 injectors...but it's your choice...there are also a few other little mods that you will have to make but they are really just vaccum lines and such
    NJ
    Can we get pictures when done? Can you jus swap the 5.3 injectors over to the TBSS intake if needed? For the TB can you just simply swap the connector out or do you need the swap harness?
