Results 1 to 10 of 10
Thread: i need some education .
    Jun 2007
    ok first of all is my 06 6.0 an ls1 or not .?what is ls2 ls6 etc.?i was just offered a 5.7 l aluminum block motor really cheap ,and it says ls2 intake and inj.help me out here .i know i should know all this but i only have concentrated on my own build really .so it time im starting too think about stroker kit and i thought if this aluminum ? 5.7 l was a good deal i might as well jump on it.what intake will it need?ls2?red i think this is youre kinda setup right?fill me in here .
    What you should worry about is if its a gen3 engine or not. Yes, it is. The LS1, LS2, LS6, 4.8L, 5.3L and 6.0L engines are all gen3 engines. Most of the parts are interchangable between each of the engines. The gen3 engines are like all the older small block chevy engines we're used to, interchangable parts. For what you're planning on doing, I'd buy a 6.2L aluminum block and stroke it so you have a bigger engine in the long run. SDPARTS.COM builds some stroker 6.2L engines and they're nice. The nice thing about the 6.2L engine is the weight savings.
    Jun 2007
    red i can get this 5.7 alum.block for 400 .bucks.then he has a vette intake rails and inj,also.for the price should i jump on it or steer away does the 5.7 have good capabilities?and would it be a gen 3 ?and this will all bolt right up correct.just that i have it in my face and i dont want too turn down a good deal.if it compatable for a big inch motor.
    Jun 2007
    and cant i make a 427 out of this 5.7 or no?
    Jun 2007
    sorry ,and this intake is a vette intake is it a 90 mm ,and throttle bdy
    If its an LS2 intake, it should have a 90mm TB.
    The LS1 is a bad candidate for a 427 unless you want to pay a fortune for Darton dry sleeve. It can be done but its not worth it IMO. The LS1 is a nice base engine. Pass on it and focus on something more worthy like the LS3/L76/L92 block.
    May 2007
    Oshkosh, WI
    Definitely buy it for $400 and sell the 5.7L. I agree with Red, hold out for a LS3, L76, L92. I personally went the LQ9 route, that is an option for you as well but sounds like you want the weight savings. RC
    Yeah, since you already have a sweet LQ4, keep it. Buy the LS1 for cheap and take off the intake and accessories... Then sell the LS1 and make some extra cash...
