i had the same thing happen and replaced cluster .of course at 105k also,i just gotthe same letter.it does say though if you already had it changed ,have the shop fill the form out and they will refund you if justified properly.i would have a friend fill it out and send it in ,its worth a shot im gonna try too get refunded cause they all end up breaking.mho.
