Results 1 to 7 of 7
Thread: air filter question
    Mar 2004
    Springfield
    air filter question
    Pulled out my K&N drop in and cleaned it up.
    Put the oil on it and left it to dry.
    Now its just sittin on the counter and I'm wondering.
    Is that oil gonna get all over my descreened Mass air flow sensor and screw it up.
    Anyone have this issue?
    *Kinjo
    FOR ALL YOUR WHEEL, TIRE, AND ACCESSORY NEEDS
    CONTACT: EPLEY'S TOUCH OF CLASSIC 1-270-843-6892
    OR TO GET ME PERSONALLY CALL: 1-615-943-6514
    2000 Chevy Silverado 4.8L RCSB: smoked UPD, Flowmaster exhaust, De-screened MAF, Nelson 93 hot tune. Upcoming installs: trans-go shift kit, Eaton posi, billet servo, ported and polished throttle body...Near future: 6.0/4L80E install with 150 wet shot
    Aug 2005
    St. Anthony, Indiana
    if you over oiled it than yes.
    if you only lightly oiled it you will be fine. doesn't take much oil.
    true that
    2009 CHEVROLET 1500 with a MONSTER 4.8 between the frame rails!!
    Tuned by LSX Powersports ~ 4.10 ~ JBA Shorties ~ 4" Inlet/Outlet Spintech ~ Airaid Coldair
    CST 3.5" Spindles ~ Camburg Upper Control Arms ~ 2.5" CCM ~ FFR Tie Rods
    Full Throttle Suspension 3" Lift Blocks ~ Soft 8s wrapped in LT285/70/17 Silent Armors
    Mar 2004
    Springfield
    well in case i did, should I just go ahead and leave it out to dry all night to make sure any excess drains out?
    ff_jeff Guest
    it wont dry, youll have to either shke it hard or dab it allot with a cloth, or just re wash it. barley put oil on so it just chaanges the color to pink
    jus run a paper towel over it if you feel you need to. youll be fine.
    Cleaning the sensor every once-in-a-while would be a good PM procedure. The cleaner is cheap and only use MAF sensor cleaner on a MAF, nothing else.
